regalrocket Posted May 21, 2009 Report Posted May 21, 2009 Ok so heres the issue. My quad was fine, then I let my father ride it. He pussy footed it for a while, then when I got back on it, the clutch lever seems really tight. It even has a spot where it gets worse then kinda pops free. Did he ride it and weld the ball? can you tell if the ball is welded without pulling it? What would make the clutch lever tough to pull. thanks. Quote
regalrocket Posted May 21, 2009 Author Report Posted May 21, 2009 Update: After looking at the clutch arm, the arrows are not even close to being lined up. The adjustment arm is about 3/8 of an inch out of alignment towards the stator side. Did the adjuster just loosen up? Quote
regalrocket Posted May 21, 2009 Author Report Posted May 21, 2009 Disregard. I tore it all down. Its the clutch cable. It must have broke a strand internally. Quote
2strokesmoker Posted May 22, 2009 Report Posted May 22, 2009 Disregard. I tore it all down. Its the clutch cable. It must have broke a strand internally. Good to know bud! :thumbsup: Quote
