Emmerrrrr Posted May 18, 2009 Report Posted May 18, 2009 Heres the mods aggressive trail port, 4 mil crank, 2 into 1 pipe, v force reeds, kn filter with lid got in the middle, coolhead with 24cc domes, stock carbs Im in ohio i thinks its 800 above sea level tempature is 60-70 out right now Right now I got stock pilot it screw out 2 turns 300 main needle all the way up the richest Its got hesitation through out the powerband Just cant get it tuned in Thanks for all help Quote
GrMeyer Posted May 18, 2009 Report Posted May 18, 2009 umm what filter set up are you running and your needing to up the pilot... and the mains for a starter. Quote
AKheathen Posted May 18, 2009 Report Posted May 18, 2009 is the hesitation like a stutter, a bog when you push the throttle a little more? did you put the needle all the way up to make it run better. it does sound like you may need to go up on the mains. i would start with 320-330, and do a plug chop, then set the needle, then the pilot. Quote
