Hello. need help figuring out the pilot jet not sure which way to adjust size. ive got a bad quarter throttle
studder. Ive got the main and niddle on the money.... i think. It runs awsome half to to full throttle. but bogs
just before the power hits on. its not bad but i notice it. i am trying to reduce the small
just be for the power really kicks in.
any one have a sugestion on pilot jet. i think ist a little rich. but could be wrong.
is it a stutter up-to quarter throttle, or at quarter throttle. if the pilot is too big, you'll notice it right from idle, and your airscrews won't adjust up right. if it's @ 1/4 throttle, then it's in the needle. from the top hesitation, i would double check the mains, and play with the neeedles some more, and remember, the needle will seem to work good in 3 different spots, and you get it set for 1/8 throttle on up, then set the pilot.
Not trying to steal ur thread but I get a studder when its rolling onto the pipe?
Any suggI know my mains are rich320 at sea level but it does it at any throttle pos
your mains do affect 90% of the range, so get those dialed in first, then go from there. running stock reeds?
Stock stroke?porting?I ran 320s in a 4m dune port..so if its stock may be rich...
well guys thamks for the advice. the jetting seems ok now. but ill see. had the top end apart was going to rebuild it till i found id bought the wrong pistons. what apain in the but. im
just fliping the rings for now. seems to run a bit bett3er till they go for good. im sure it wont be long.
i founfd i was running one cylender most the time. on low end. had a lot of blow by on the left side.
well i recon i cnt complain even runing like that it still smoked a group of raptors. even some built ones on the strip
