banshee_boy09 Posted May 13, 2009 Report Posted May 13, 2009 I just got my banshee put back together and it done fine for a little bit, but after about 5-10 mins of riding it then I started hearing a rattling, the rattle is coming directly from underneath the clutch cover I pulled the cover off because it sounds like a stock basket that is really wore out. But I have a billet basket in it now with a new clutch pack, idk what it is, and it will do it pretty bad when it is sitting in neutral idleing but pull the clutch in, ....or put it in first gear then it will stop rattling any ideas will be greatly appreated, Thanks. Ohh and there is not slack between the gear and the basket. Quote
FireHead Posted May 13, 2009 Report Posted May 13, 2009 I just got my banshee put back together and it done fine for a little bit, but after about 5-10 mins of riding it then I started hearing a rattling, the rattle is coming directly from underneath the clutch cover I pulled the cover off because it sounds like a stock basket that is really wore out. But I have a billet basket in it now with a new clutch pack, idk what it is, and it will do it pretty bad when it is sitting in neutral idleing but pull the clutch in, ....or put it in first gear then it will stop rattling any ideas will be greatly appreated, Thanks. Ohh and there is not slack between the gear and the basket. It might be your kick starter.......... Quote
J-Madd Posted May 13, 2009 Report Posted May 13, 2009 If it stops when you pull the clutch in it's probably normal clutch chatter. Nothing to worry about. Quote
banshee_boy09 Posted May 13, 2009 Author Report Posted May 13, 2009 Ok, everything looks to be fine with the clutch.. The rattle is pretty loud, quite a bit louder than it was ever before. But it does stop most of the time when you pull in the clutch, its definately not the kickstarter...or atleast the outside part isnt rattling. Quote
