hey guys just bough a set of cpi drag pipes on here and i know they mount to the pegs somehow... is there a mount or something i can get from the hardware store i can use? i am supposed to be leaving for the dunes tomorrow...
You will have to fab some mounts. Make sure it is a fairly beefy piece of chromoly or mild steel. No aluminum. You will want to use a rubber mount to help dampen the vibrations so you don't crack a pipe mount. I use rubber stoppers for automotive shocks that can be bought at any auto parts store. There are other methods as well....
I usually just get some 1/8" thick by 1" wide steel from lowes and bend it to the length I need and use rubber bushings. Never had any problems.
