ok here we go. friends shee wont start until you squirt gas in carbs then it will start right up, you shut it off then it will start every time once its been started so figured that it was pilot jet cloged took part the carbs and yea they was cloged i cleaned them out for him and the whole carb we put them back on and now when you start it you have to choke it and then it will start and only the right side has compresion and the left isnt doing any thing then you take the choke of then the left side is working and the right side isnt. im puzzled it just been built, has new carbon reeds, cool head, help us please. thanks
look in the back sides of the carbs on the airbox or filter side and push the throttle a little bit and make sure the the slides are pulling up evenly. possibly something got put back together a little different and the carbs may be out of sync.
there the same and we dont run a air box we use k&n poods
