sparkyjohn Posted May 4, 2009 Report Posted May 4, 2009 hi guys thanks for all your help with last problem!! got another for ya, my banshee had a small feul leak and a high idle so i took the carbs out and cleaned them and checked for air leaks but when i put it back together the feul leak was fixed but still high idle, it also makes a funny popping sound from one exaust almost as if that cylinder isnt firing the same on both sides?? also more exaust gases out of one side. and if i put my hand over the good exaust then off again it idles fine and all is well until i rev it and it goes back to high idle again? something not right but when its driving all is fine can anyone help? Quote
AKheathen Posted May 4, 2009 Report Posted May 4, 2009 ok, first, do a carb sync. you can search on here and youtube to find out how, and then use the exhaust pressures to fine tune the balance. look for exhaust leaks by spraying carb cleaner all around the intakes while it's idling. also, if you still have the tors, they may have to be lubed along with the thrittle cable. i had the same problem, and chased it for a while, from sticky slides to jetting and airleaks, untill i finally narrowed it downto the tors. when it idles up by just touching the throttle, just blip it, and should go back to normal. i was watching the slack in the cable change. i'm just waiting on the tap to get rid of that junk. Quote
