Might sound like a dumb question but from what i was told no question is dumb lol so here it goes....
The rubber plugs in the bottom of the cylinders. Are they needed or not? The gasket dosent have a hole that matches.......I think the hole is strictly for the casting when they make the jugg. Can I continue my build without these plugs? Waiting on the dealership and they are taking forever!!!!!! :shrug:
You need them.
I've tried in the past to fill them with RTV in a pinch...but you really need the plugs.
As said, the gasket won't hold the coolant pressure that the rubber plugs will.
honestly i've never tried running a set of jugs without them, i just pull em/ clean em up then threebond them back in....
Yeah when i got my shee only one cylinder had the plug. Then I pulled the other one when I had all the powder coating done. Anybody know someone with a set?
