i was riding today and i was just getting it warmed up and all of the sudden it just quit running and shut off. it semmed like i forgot to turn my gas on but i checked and it was on. does any body know what couldve haappend???? i just had rebuitl and have about 6 hours on it and just installed a +4 timing plate, would this have anything to do with it?? pleae help
  • 2 weeks later...
Firstly,change your plugs,maybe fouled,if not plugs,check your kill switch,and then remove your stator,maybe a broken key,check your stator,check your coil wires around the sharp corner if it broke or burnt off,myne burnt the wires at one stage,check that and please let me know if you found the problem
Check where you plugged your computer and stator together..Make sure there connected.See if you have spark.If you have spark see if the choke tube between the two carbs is on.You just put a timming plate at +4,What mods did you get?The pickup for the flywheel may be loose,make sure you gap it with a buisness card and tighten back down.. Check woodruff key also..
