I have a couple if you still need one.
How much do you sell them for, and what all is involved to make them work wtih a stock wiring harness?
you wont have a wireing harness witht the pvl
Cool... are they difficult to setup, and can you still integrate them to use your stock on/off switch, lights, etc.?
They are a racing ignition, so you won't be able to run any lights with it. They are fairly easy to set up, but you will need a dial indicator so that you can find TDC, measure, and set your ignition timing.
