Ok guys I guess Im being a straight dumb ass from being so tired the last couple days, but why wont the a-arms come out of spindles? the stud that's connected to the ball joint will not pop out how do you take the a-arms of the spindles?
But how do you get them out I tried using a rubber mallet and using force and is didn't come out? maybe try some heat?
picle fork, or you can make a press out of a bolt, nut, and a piece of pipe. just be carefull not to damage the threads
I make a press ouda my flywheel puller or screw a nut 3/4 threads so not to damage and hit it with a bfh
Well, they can be such a bitch to get a swing on so it makes it tough..
But like the others have mentioned.. I use a BFH, have a nut on there so you don't jack up the threads and then find something that you can put on there to smack.. Trying to remember what I used in the past.. Cant remember if it was some sort pry bar or just a metal rod of some sort.. Sure you get the idea though.. Its just a bitch to get any decent angel or hit on it without using some sort of "extension"....
RIPPEN
