toolman Posted April 21, 2009 Report Posted April 21, 2009 I have a trans problem and need new top end gasket went to order them and they need to know the bore size. I can not remember the size do i really need to tell them the bore size. thanks Quote
fastrthnu Posted April 21, 2009 Report Posted April 21, 2009 I have a trans problem and need new top end gasket went to order them and they need to know the bore size. I can not remember the size do i really need to tell them the bore size. thanks Ive never needed a bore size. If you went to a powersports shop, most likely they are a fucktard. Unless they want to know it you have a big bore/cub cyl? Quote
toolman Posted April 21, 2009 Author Report Posted April 21, 2009 Nothing special. i just can't remember the bore size it has been a while. I have not taken it apart and wanted the gaskets so i could put it right back togather. They told me cometic you have to have the bore size and they also sold versa and they did not require a bore size. I wanted the cometic because i have had good luck with them and cheaper than OEM. Quote
DopeyTripod Posted April 21, 2009 Report Posted April 21, 2009 parts guy sounds like a lazy fuck that dont want to help. Quote
