Sandfrk33 Posted April 21, 2009 Report Posted April 21, 2009 After installing a tm designworks case saver, I kept hearing a crazy ass noise. Sounds like a wood block from a drum set. I can hear it when rolling to a stop. Anyone else ever heard this before, or am I about to spend somemore cash. I hope its the links of the chain rubbing across the case saver. Quote
swrbansheeboy Posted April 21, 2009 Report Posted April 21, 2009 did you rout your chain correctly? i've seen guys run there chain on the wrong side of the rollers before and it will make all sorts of noise and destroy the roller... you should be able to see if the chain is comming in contact with your case saver.... Quote
