lt1bird Posted April 17, 2009 Report Share Posted April 17, 2009 (edited) Well its running....Seems fine when on the pipe..... at 1/8 to 1/4 throttle its very choppy.... vibrates and seems unhappy. It has the following 535 150 psi compression +5 timing big bore pipes with silencers 38mm kehin carbs 172 mains 58 pilots few hunderd feet from sea level 70 degrees had 58 pilots....thought it was a bit rich...changed to 52 pilots....Did not help....maybe seems a bit lean at 1/8-1/4...... Are people running more than 58's on these engines? Ill put some 60's in and see what happens. It does not rev clean down low......revs rough until it gets to higher rpms(4k) or higher throttle opening until it runs smooth... Does everyones run crapy just off idle....super crisp from idle to 1/4 throttle?? Thanks for the help! Edited April 17, 2009 by lt1bird Quote Link to comment Share on other sites More sharing options...
Keyser Soze Posted April 18, 2009 Report Share Posted April 18, 2009 Ill be honest with you. Jetting for something like that is almost impossible. Your best bet is to just chalk it up.....crate up everything you have and get it shipped out to me. Start fresh. Ive heard CC's ending on odd numbers are a bad omen. You need to rebuild maybe shoot for 536 or 534.....Ill pm you with my shipping address. Get me your paypal and ill give you 70 bucks so you can get that thing shipped out. Quote Link to comment Share on other sites More sharing options...
lt1bird Posted April 18, 2009 Author Report Share Posted April 18, 2009 You only charged my buddy $60 for shipping.... now it's $70... Quote Link to comment Share on other sites More sharing options...
pabansheematt Posted April 18, 2009 Report Share Posted April 18, 2009 Well its running....Seems fine when on the pipe..... at 1/8 to 1/4 throttle its very choppy.... vibrates and seems unhappy. It has the following 535 150 psi compression +5 timing big bore pipes with silencers 38mm kehin carbs 172 mains 58 pilots few hunderd feet from sea level 70 degrees had 58 pilots....thought it was a bit rich...changed to 52 pilots....Did not help....maybe seems a bit lean at 1/8-1/4...... Are people running more than 58's on these engines? Ill put some 60's in and see what happens. It does not rev clean down low......revs rough until it gets to higher rpms(4k) or higher throttle opening until it runs smooth... Does everyones run crapy just off idle....super crisp from idle to 1/4 throttle?? Thanks for the help! Are they PWK's or PJ's ? I think your pilots and mains are rich if you have PWK's. What needles do you have? Quote Link to comment Share on other sites More sharing options...
lt1bird Posted April 18, 2009 Author Report Share Posted April 18, 2009 I have pwk carbs got "deg" needles in there now......... trying "del" needles tommorow... Maybe im being to critical? I see other video's online for banshee's and they seem to be burbbling at 1/8" -1/4 throttle..... Quote Link to comment Share on other sites More sharing options...
lt1bird Posted April 18, 2009 Author Report Share Posted April 18, 2009 was out tuning....was coasting down a long hill and it seemed like it was starting to get very tight.....Pulled the clutch and coasted. Started it back up after a few minutes as I was only a little bit from home..... Guess my pilot jet being to small could cause that? im running 40:1 ratio.... Quote Link to comment Share on other sites More sharing options...
lt1bird Posted April 19, 2009 Author Report Share Posted April 19, 2009 Went back to the 58 pilot jet....Let the bike warm up this time........adjusted the idle to 2k.... then adjusted the air screw....The happy setting is about 2-1/2 turns out. At what point will the air screw stop letting more air in? 2-3-4 turns????? seems to run fine...a little sputtering at 1/8 to 1/4 throttle.....Should I raise needle clip position one to try and reduce the sputtering? Am I on the right track? Quote Link to comment Share on other sites More sharing options...
