ryansedy Posted April 17, 2009 Report Posted April 17, 2009 recently bought a 4mm cub motor ported, be running CPIs or Shearers, I ride mostly all sand and some dragging. Mostly duning hill climbs, what size carbs should i run? over 35mm right? run 110 octane gas. Quote
shanYE west Posted April 17, 2009 Report Posted April 17, 2009 I like the 39pwk's myself for the 4mil cubs.. Quote
ryansedy Posted April 17, 2009 Author Report Posted April 17, 2009 thanks thats what i was thinking.. Quote
Darthwall Posted April 18, 2009 Report Posted April 18, 2009 35's will be just fine for it if you go with too big of carbs you start to loose bottom end if you dont mind that stick some big ones on there for the top end Quote
dragbanshee98 Posted April 18, 2009 Report Posted April 18, 2009 35's will be just fine for it if you go with too big of carbs you start to loose bottom end if you dont mind that stick some big ones on there for the top end x2 on that... i would say 35's to 40's would work for that... it all depends on where you want the power to come on with making the choice Quote
1996dragshee Posted April 18, 2009 Report Posted April 18, 2009 i second on the 39's.good carb for hill climbing,dragging with that motor set up.If you got to small you will lag top end,keep that in mind Quote
