NitroTate Posted April 18, 2009 Report Posted April 18, 2009 Yeah like someone else said if you don't want to make one you can find them, try ebay or Kevin at Herr or F.A.S.T. www.farmandsandtoys.com You have to eliminate potential problems, I've listed everything I could think of so if you've eliminated all of those then your next step is to check for air leaks unless someone else has any other ideas but that's a good next step. Quote
manny 2004 banshee Posted April 18, 2009 Author Report Posted April 18, 2009 hey i was just wondering how you get pictures on your signature Quote
AKheathen Posted April 18, 2009 Report Posted April 18, 2009 i know you said that you have new plugs, but is that before or after the problem. do they look burnt just after trying to start it? you can loosen the carb clamps on the intake boots and turn them, so that you can tighten (by hand only) the caps, because that will cause issues. make sure that the choke tube is in place. after that, put some brand new plugs in and try to start it without touching the throttle (about 10 kicks) if it doesn't start, pull a plug and see if it has fuel on it. if so, check for spark. unplug the tors module. it's a little black box, to the left of the coil, with a 3 wire pigtail (black, black/white, and yellow/black) also, check the harness next to the airbox for melting on the exhaust. here's a diagram if you need Quote
