I just got a trail tech vapor and wanted to get all the tricks from you guys that have it to make sure I get it right the first time. Like best place to mount magnets, best place for engine temp sensor, best way to tap in power, best way for tach wire and where did you get your ground from? Thanks in advance
i cut my dustshield since i dont use them anyway and mounted my magnet there.
the temp sensor goes between the head and radiator.
i used the hot wire (cant remember which color) that feeds the dimmer switch.
i ran my ground wire to one of the screws that holds the gas tank down, but you can choose any bolt that screws into the frame.
Awesome thanks dude I'll let you know how it turns out.
