Drewski Posted April 9, 2009 Report Share Posted April 9, 2009 my shee sucks in water even small puddles is there a snorkel you can get for a shee? reviews? price? Quote Link to comment Share on other sites More sharing options...
BSHEE400 Posted April 9, 2009 Report Share Posted April 9, 2009 are you already running the stock airbox and snorkel? Quote Link to comment Share on other sites More sharing options...
POORBOY350 Posted April 9, 2009 Report Share Posted April 9, 2009 YOU shouldnt be getttin any water in your air box if its stock from just small puddles i wouldnt thnk Quote Link to comment Share on other sites More sharing options...
MILO Posted April 9, 2009 Report Share Posted April 9, 2009 drewski, i guess it depends on what you call a puddle. :biggrin: with the stock setup you shouldn't be seeing any water in the box. i trail ride mine in wet muddy conditions sometimes without a lid on the box. it gets a little wet, but not too bad. hopefully the outerwears cover i just put on will help keep things out a little more. especially those damn little seeds from the weeds. i hate picking those little buggers out of the filter. :mad: Quote Link to comment Share on other sites More sharing options...
Drewski Posted April 10, 2009 Author Report Share Posted April 10, 2009 no im not running a snorkel but i figured out by plugging the drain hole on the bottom of the air box i have not had any bogging or water . im not sure if it should be left open though? Quote Link to comment Share on other sites More sharing options...
CoreyReid Posted April 10, 2009 Report Share Posted April 10, 2009 with my trail riding experiances, if you plug it, the water that does get in there cannot get out. the only place it can go is through you filter, intake, and so on. no im not running a snorkel but i figured out by plugging the drain hole on the bottom of the air box i have not had any bogging or water . im not sure if it should be left open though? Quote Link to comment Share on other sites More sharing options...
fastrthnu Posted April 10, 2009 Report Share Posted April 10, 2009 On my friends big bear 350 we put a one direction check valve in the bottom of the airbox, and ran a radiator hose extension from the tip of the snorkel and cut it off at tank level then put a u of 2" pvc in the end of it so water cant fall down it. if you ride alot of water it doesnt hurt to silicone your connectors and plug boots. my banshee doesnt do water. Quote Link to comment Share on other sites More sharing options...
MILO Posted April 10, 2009 Report Share Posted April 10, 2009 with my trail riding experiances, if you plug it, the water that does get in there cannot get out. the only place it can go is through you filter, intake, and so on. exactly, that's why i leave mine off. occasionally we have to cross a creek too so i figured it would be best to let the water just run right back out if any does get in the box. Quote Link to comment Share on other sites More sharing options...
