Does anyone know where i can find a complete RZ engine? i want one for my banshee. Well before i buy one i want to know everything i can about them. so if any of you guys know alot about them please give me your knowledge..
BRIAN
There's one in the for sale section. Top end, servos, wiring, and a few other things, I think.
rz cyls, head and gasket, bolt on exaust flanges, pv servo, cdi, reg, pv servo control, and batt. eliminator. im not sure if a yfz stator will splice in, i cant imagine why not. i have an rz200w on mine. coil will work. you will also need a pipe to clear the pv on the stator side cyl. pts and rockets are the most common used.
the cases are the same other than the older rz ones have holes for cluster gauges. you can put rz cylinders on your std cases.
