hey, i can't remember how wide you can safely go with the exhaust port without wearing the rings down too fast. i think i remembered like 70 degrees, but not too sure. it's only for a little 50cc, but i have to port the exhaust a bit so i can build a pipe that will fit. :thanks:
70 degrees?? i think you mean 70% of bore diameter. my graham bell book says up to 73% can be used. my snowmobiles main exhaust port is 73% of bore diameter.
ex, if your cylinder bore is 1.530", and you want the exhaust port width to be 70% of the cylinder bore diameter, then the port width will = 1.071"
1.53" X .7 = 1.071"
1.53" X .7 = 1.071"
what he said. Bore:exhaust width ratio not typically to exceed 70-72%. More than that and the ring will beginning deflecting into the port too much.
