530grafix Posted March 31, 2009 Report Posted March 31, 2009 As many of us know taking care of our polished parts can be a real pain. A Brilliant Two-Component Clear Coating GLISTEN PC is a High Gloss, Rock Hard, Water-clear topcoat designed for spray or brush application over all metal surfaces, including highly polished aluminum and chrome surfaces. GLISTEN PC will not leave brushmarks, and will dry in less than one hour, but will take 3-4 days to reach maximum hardness. When GLISTEN PC is first dry to the touch, it will appear to be very soft. Avoid touching it for several days until it becomes hard and tough. Accidental contact could damage the surface before full cure has taken place. Like many other coatings, GLISTEN PC is a MOISTURE-CURED coating, which means it is strengthened by exposure to moisture. It will never crack, chip, peel, or yellow, and is very flexible as well. IDEAL USES: As a protective coating on aluminum wheels, chrome bumpers, marine railings, chrome or aluminum covers, grills, handles, ornaments, lights, etc So, I have a Pint kit that is more than enough todo all the polished parts on your bike. Ill take 25 bucks shipped for the kit. Quote
wacko2000 Posted March 31, 2009 Report Posted March 31, 2009 ATTENTION.. I have used POR15 products and they are pretty good. If this clear coat works so well why are you selling it? I was wondering what/why people use a clear coat after powder-coated, what does it do? Quote
jclc43837 Posted April 1, 2009 Report Posted April 1, 2009 ATTENTION.. I have used POR15 products and they are pretty good. If this clear coat works so well why are you selling it? I was wondering what/why people use a clear coat after powder-coated, what does it do? i have a small powdercoating business and a coustomer wanted a clear coat over the color, the reason being was they did not wont the color to scratch up, and then i explained if you scratch the clear coat you still have the same problem. Quote
530grafix Posted April 2, 2009 Author Report Posted April 2, 2009 This product is intended to be put over polished aluminum products. It will reduce the amount of maintenence on your polished parts and will prevent it from oxidizing, hence less polishing maint! I had 2 kits and i used one.. Quote
