dans86 250r Posted March 31, 2009 Report Posted March 31, 2009 my banshee will go through the gears fine but when im on it hard in a drag race i dump it in second and itl go into third but after that i try to shift it up and its still in 3rd then my girl friend passes me on her 450 cuz it wont go in fourth so do you guys have any ideas it has a shift star fresh clutch and iv adjusted that little stud so it lifts the shaft up as much as possible any ideas will be much apreciated Quote
SAVAGE420 Posted March 31, 2009 Report Posted March 31, 2009 Could be that you second shift fork is worn out. Did this happen all of a sudden or gradually? Quote
tidos76 Posted March 31, 2009 Report Posted March 31, 2009 check your shift shaft adjustment. sometime the eccentric screw will get worn or come loose and cause it to do that. if thats not it it is more than likely inside the cases Quote
dans86 250r Posted April 1, 2009 Author Report Posted April 1, 2009 i had that adjuster bolt come loose and it wouldnt shift very good at all but after i bought a new one and put it on it just hasnt ever been right since it is frusterating it shifts great just cruising around but not under hard power so i guess its time to split the cases Quote
dans86 250r Posted April 3, 2009 Author Report Posted April 3, 2009 i had that adjuster bolt come loose and it wouldnt shift very good at all but after i bought a new one and put it on it just hasnt ever been right since it is frusterating it shifts great just cruising around but not under hard power so i guess its time to split the cases any body have any other ideas Quote
TJScott Posted April 3, 2009 Report Posted April 3, 2009 you have to adjust it to a certain spot, not just as much as possible. make the clutch engagemant nipple line up with the arrow on the case. Quote
dans86 250r Posted April 3, 2009 Author Report Posted April 3, 2009 (edited) you have to adjust it to a certain spot, not just as much as possible. make the clutch engagemant nipple line up with the arrow on the case. do you or anybody else have a pic of that and if you are talking bout the one that u use to adjust the free play in the clutch its gone i had a chain break and bust the shit out of that casting so its welded back together and the arrow is gone Edited April 3, 2009 by dans86 250r Quote
pabansheematt Posted April 4, 2009 Report Posted April 4, 2009 my banshee will go through the gears fine but when im on it hard in a drag race i dump it in second and itl go into third but after that i try to shift it up and its still in 3rd then my girl friend passes me on her 450 cuz it wont go in fourth so do you guys have any ideas it has a shift star fresh clutch and iv adjusted that little stud so it lifts the shaft up as much as possible any ideas will be much apreciated I had the same problem last week. Found that the rivot at the end of the shift shaft was worn and wobbling. I could actualy see marks on it, were it was going past the shift star. Hope this helps. Quote
CadillacBanshee Posted April 5, 2009 Report Posted April 5, 2009 I had the same prob a while back. My clutch rod was worn and the clutch was not being fully released when i was trying to shift. appearently it was happening all the time, but i noticed when i was racing only. Good luck. Quote
