figster Posted March 31, 2009 Report Posted March 31, 2009 i need help, any ideas are welcome. i was recently given a pair of mikuni flat slides 34, but they need to be rebuilt because they leak gas. they told my it was probably the needle jet, but the problem is that i can't find any web site that sells the rebuilt kit and if the do the ask you for model number or part number, which i don't have. all i got is that they where on a banshee and they are mikuni 34 flat slides, also on the side of the carb it is marked like this 34 12 A HD 34 any clues on what model these carbs are? Quote
SAVAGE420 Posted March 31, 2009 Report Posted March 31, 2009 Sounds like they are the Mikuni TM Series. Check out all the parts list links and exploded view links in this link here, under the TM Series Carburetors. http://www.carbparts.com/mikuni/mikuni_atv.htm#TM Should be everything you need there. Carb Parts Warehouse is good people. I bought my carbs from them and they hook up. :thumbsup: Quote
uwenr Posted March 31, 2009 Report Posted March 31, 2009 i need help, any ideas are welcome. i was recently given a pair of mikuni flat slides 34, but they need to be rebuilt because they leak gas. they told my it was probably the needle jet, but the problem is that i can't find any web site that sells the rebuilt kit and if the do the ask you for model number or part number, which i don't have. all i got is that they where on a banshee and they are mikuni 34 flat slides, also on the side of the carb it is marked like this 34 12 A HD 34 any clues on what model these carbs are? Try Sudco they have a ton of carb parts http://www.sudco.com/mikuni.html Quote
