upstate1000 Posted March 28, 2009 Report Posted March 28, 2009 just rebuilt the top end on it, put her all back together and had no spark, checked all parts from stator to ignition coil, all check out for resistance, still no spark at spark plugs!!! any ideas? Quote
AKheathen Posted March 28, 2009 Report Posted March 28, 2009 did you set the pickup gap right? at the cdi, check that the red/black wire has continuity with ground, and that the black/white wire doesn't. also, check that the black wire has continuity with the frame, engine, and black wire to the coil. what was the ohm readings? Quote
upstate1000 Posted March 28, 2009 Author Report Posted March 28, 2009 did you set the pickup gap right? at the cdi, check that the red/black wire has continuity with ground, and that the black/white wire doesn't. also, check that the black wire has continuity with the frame, engine, and black wire to the coil. what was the ohm readings? I have continuity from b/w to ground (frame), what does this mean? Quote
AKheathen Posted March 28, 2009 Report Posted March 28, 2009 I have continuity from b/w to ground (frame), what does this mean? that's the "kill" wire. it goes to the kill switch, the keyswitch, and the tors. make sure the tors box is unplugged(little black box with 3 wires, to the left of the coil) if you bypassed the key, make sure the black/white wire is not connected to anything. and, of course, make sure your bike is in on/run when you test :thumbsup: Quote
