Im working on my buddies banshee which has no spark. I have a few questions for you fellas. When it comes to the TORS which was previously disconnected, is that okay, i mean simply disconnect the carb switches, TORS control box, throttle switch etc. and leave them hanging because thats how it is? He has aftermarket tops for the carbs and a twist throttle. Now i have ran through the harness and everything else and everything tests in spec(all switches, pick up coil, source coil etc). The only problem i have is when testing the ign. coil. The primary is fine but when testing the secondary(cap to cap) im getting 10.75 Mega or M Ohms instead of any K Ohm reading. Now this means millions correct which would indicate my coil is toast? Any help would be appreciated!! Thanks
