What do you guys think Lean/Rich or just right on the mains? The top pic is the left cylinder and the bottom is the right cylinder. Mods are in my sig. Elevation is 600 feet above sea level, Temp is 65 degrees and humidity is around 80%. Mains are 320's, pilots are 25 and the needles are on the 4th clip down.
Those were the exact steps I took. I still have a little throttle tip in burbble/hesitation do you think a little larger pilot jet(27.5-30.00) will take of that?
Sammy, try dropping the needle one notch to see if it helps the bog/hesitation. I had to go down on needle(up with the clip) when i went to bigger mains. When you get bigger on the mains, it will also fatten it up some in the middle, so leaning a click might take away your bog. Also, plugs look good, but watch temps, if it drops too much go up on the mains.
It seems to really do it from about 5%-15% throttle position. Also it got better when I went down a hole on the needle and turned the air screws in a half a turn. So now the clip is in the fourth hole and air screws are at one turn out. That's why I figured it was time for a larger pilot jet.
