Loc Posted March 27, 2009 Report Posted March 27, 2009 Ok I will give you the specs then the problem. 1999 Banshee -FMF Fatties, K&N Pods -310 mains, middle clip, 25 pilot (stock carbs, tors removed) -Airscrew 2 turns out -cleaned carbs -new plugs -compression is good -Temp 45 degrees and elevation is 1400 feet The bike will not start cold. If I spray a small mist of starting fluid or gas into the carbs it will fire up and run great (I know not the best Idea). There was oil/gas coming out the left pipe, I think that is fixed. Any help would be great. Yes I searched, found some help tried those things and it has brought me here. Thanks in advance Quote
Sammy Posted March 27, 2009 Report Posted March 27, 2009 27.5 pilots and 1 1/2 turns on the air screws. The larger pilot will help cold start. You may have to lean the clip out one notch. Quote
Loc Posted March 27, 2009 Author Report Posted March 27, 2009 Ok now I am confused. Went out this morning first kick and it started. There is alot of gas/oil mix coming out the left pipe. Quote
Sammy Posted March 27, 2009 Report Posted March 27, 2009 Is there a significant temperature difference between today and the last night you rode? More that say 10-15 degrees? Are you sure both air screws are set equally? Possibly trash stuck in the needle and seat or maybe a dead hole? Quote
SonOfSand Posted March 27, 2009 Report Posted March 27, 2009 Did you recently have the bowls off the carbs for any reason? Quote
Loc Posted March 27, 2009 Author Report Posted March 27, 2009 Yes I removed the bowls while cleaning the carbs Quote
SonOfSand Posted March 27, 2009 Report Posted March 27, 2009 Yes I removed the bowls while cleaning the carbs I think I know your problem, look on the front of bowls, on one bowl there should be a small metal bump sticking half way out, it is about the size of a BB. This bowl needs to be on the left carb if you are sitting on the quad. You put the wrong bowl carb, the choke wont work with out it, I just had the same problem an hour ago. LOL! Quote
Loc Posted March 27, 2009 Author Report Posted March 27, 2009 I checked the bowls and they are on the correct side. I did notice out of the pipe that is leaking oil the exhaust is cold and the other side is hot. Quote
C&B Posted March 27, 2009 Report Posted March 27, 2009 Ok now I am confused. Went out this morning first kick and it started. There is alot of gas/oil mix coming out the left pipe. are you leaving the fuel on all the time? If so youre filling the crank with gas, thats why its a bitch to start. Quote
Loc Posted March 27, 2009 Author Report Posted March 27, 2009 I turn the fuel off when it is not running. I pulled the plug and kicked it over and the plug had spark. I started the Banshee and unplugged the left cylinder and the idle smoothed out and almost seemed to run better. The bike now starts first kick every time. Quote
Loc Posted March 28, 2009 Author Report Posted March 28, 2009 the left carb should have the brass tube that in the bowl correct Quote
