RARRACING Posted March 26, 2009 Report Posted March 26, 2009 im having trouble with my banshee it will start runs fine till i hit the gas and it bogs and dies iv checked the jetting and the reeds and carbs all fine spark is strong new spark plugs timing is right i just have no idea why it is doing this plz help thanks ryan Quote
hercalmighty Posted March 26, 2009 Report Posted March 26, 2009 Do you still have your TORS hooked up? If so disconnect it Quote
RARRACING Posted March 26, 2009 Author Report Posted March 26, 2009 (edited) Do you still have your TORS hooked up? If so disconnect it yes it still does it :: Edited March 26, 2009 by RARRACING Quote
hercalmighty Posted March 26, 2009 Report Posted March 26, 2009 Ok. Do you mean yes the tors is still hooked up or its disconnected but still acting up? I was a little confused on the last post there Quote
peterlocal22 Posted March 26, 2009 Report Posted March 26, 2009 if your sure its not the jetting then you might want to remove the tors i think rocky mountain sell the kit Quote
RARRACING Posted March 27, 2009 Author Report Posted March 27, 2009 could a bad coil make this happen how can you tell if your reeds are bad Quote
