tidos76 Posted March 17, 2009 Report Posted March 17, 2009 i've been thinkin about doing some asphault drag racing just for fun with a few buddies. The track close to me is a NHRA track so i must meet NHRA guidelines. my question is how are you guys doing your chain guards? i have a chrome swingarm and i dont want to weld tabs to it just for the chain guard. Any suggestions? I;f you can post up some pics of your setups. Quote
tony cub Posted March 17, 2009 Report Posted March 17, 2009 the one i use bolts to the chain slide,near the rear sproket,and comes up around the chain..hope this helps..i dont have pics.nhra aproved.. Quote
sleeper06 Posted March 17, 2009 Report Posted March 17, 2009 The set-up on my sig is bolted to the arm,I made it with diamond plate and a brake,my old set-up like tony said bolts onto the back slider.I bought a peice of aluminum angle cut the front on an angle bolted it to the top chain roller hole,got it to the height I wanted made a flat bracket off rear slide up to peice of angle and bolted it together,with that set-up I had to strut the rear Quote
dragfan09 Posted March 18, 2009 Report Posted March 18, 2009 (edited) Here's pics of my. 2"x1/4" aluminum. With NHRA rules. It has to be right up against the motor cases. Above the front sprocket and over the rear sprocket, Edited March 18, 2009 by dragfan09 Quote
dragfan09 Posted March 18, 2009 Report Posted March 18, 2009 Here's pics of my. 2"x1/4" aluminum. With NHRA rules. It has to be right up against the motor cases. Above the front sprocket and over the rear sprocket, Quote
dragfan09 Posted March 18, 2009 Report Posted March 18, 2009 Bolted to chain slider. Also to the frame. Quote
tidos76 Posted March 18, 2009 Author Report Posted March 18, 2009 sweet! thats exactly what i needed to see. You mounted the front to the top chain roller? Quote
Wicked Motorsports Posted March 19, 2009 Report Posted March 19, 2009 my old bike. Very nice and clean! got anymore pics? Quote
bam_Banshee_02 Posted March 20, 2009 Report Posted March 20, 2009 Bolted to chain slider. Also to the frame. How much space is between your metal bracket and the top chain? How far did you go up to prevent you chain from slapping that guard? Quote
rb0804 Posted March 20, 2009 Report Posted March 20, 2009 (edited) NYUK Is that an outboard bearing support? Where did you get it? The only one that I have seen was from packard. Are those grand river pipes? Edited March 20, 2009 by rb0804 Quote
NYUK Posted March 20, 2009 Report Posted March 20, 2009 NYUK Is that an outboard bearing support? Where did you get it? The only one that I have seen was from packard. Are those grand river pipes? yes grr pipes. bearing support was from chuck wilburn. chariot makes them also. Quote
njbanshee Posted March 20, 2009 Report Posted March 20, 2009 NYUK that bike is sick. I never seen that done before. Some day i'll get there. Quote
