boneyardbanshee. Posted March 16, 2009 Report Posted March 16, 2009 What material are the stock sleeves made from? I thought I saw it in a post some time ago but can not retrieve the info. The posts I have found refer to them as Iron, Cast Iron, or steel. Quote
boneyardbanshee. Posted March 16, 2009 Author Report Posted March 16, 2009 yep, that is what I thought. Anyone else want to chim in on this? I have a bet going with my know it all brother. Or someone have definitave proof? Quote
TJScott Posted March 16, 2009 Report Posted March 16, 2009 the sleeves themselves are steel i believe. Quote
TJScott Posted March 16, 2009 Report Posted March 16, 2009 i know the outsides themselves are cast iron, but for some reason im wanting to say the sleeves are steel, im not sure why. Quote
poorboystoys Posted March 16, 2009 Report Posted March 16, 2009 ive heard cast iron but not sure Quote
tony cub Posted March 16, 2009 Report Posted March 16, 2009 the cylinder is made of aluminum.and the sleeve is steel Quote
poorboystoys Posted March 16, 2009 Report Posted March 16, 2009 the cylinder is made of aluminum.and the sleeve is steel its cast, not aluminum some can be but were talking about stock Quote
spike Posted March 16, 2009 Report Posted March 16, 2009 its cast, not aluminum some can be but were talking about stock Its cast aluminum... and im pretty sure the sleeve would be steel as cast iron would be somewhat porous which is not really what you want in a sleeve application. could be wrong tho. Quote
duner Posted March 16, 2009 Report Posted March 16, 2009 cyl is aluminum, sleeve is cast iron. 100% sure. Quote
Fireroad Express Posted March 16, 2009 Report Posted March 16, 2009 hmmm, i always thought the cylinders were cast aluminum and the sleeves were steel. a cast iron cylinder would make for one heavy f*@$ing cylinder! then again, isn't there some kind of chemical reaction or oxidation that takes place between steel and aluminum? Quote
deckheight Posted March 16, 2009 Report Posted March 16, 2009 I'm 100% sure also... cyl is aluminum, sleeve is cast iron. 100% sure. Quote
C&B Posted March 16, 2009 Report Posted March 16, 2009 I'm 100% sure also... Yep thats why the cyls are polished on so many! Quote
boneyardbanshee. Posted March 19, 2009 Author Report Posted March 19, 2009 So after further research I ran across THIS SITE wich states that the stock sleeves are in fact cast iron. So I won a hundred bucks and those of you who didnt know now do. Thanks guys. :beer: Quote
