ok i know some will flame for using these hoses but oh well.
I'm using the hoses from the hardware store. i have been told you can dye them by boiling them in some clothing(rit) dye. How long do you have to boil them? i have had a test peice in for about 15-20 min and still nothing. thanks in advance
You just have to get a nice big pot and heat the water and RID RIT what ever the name of the dye is in it. You dont have to bring it to a boil but it needs to be close. I think mine had to sit in the dye for about 8 mins. Depending on what color your try to do will depend on how much dye to add and how long to let it soak. For the blue I used some dark ass navy blue dye. You might not be having luck because of the color? Not sure. I did it a few times beecause I didnt get the hoses the correct length the first time.
ok thanks. I;m going green. i put enought dye in it to turn the water almost black. I'm going to try it again tonight. maybe i got the water too hot? or maybe the green wont take. :shrug:
you got the hose from the plumming section at like Lowes or Home Depot? And it's the hi pressure hose? If so it is the right stuff, it might be the color your trying to use wont take for some reason?
