skinindustries Posted March 7, 2009 Report Posted March 7, 2009 Ok i am taking all the useless wires off my harness, and i ran into this blue one that goes to the voltage regulator(next to the CDI). Do i need that if i am not goin to run lights? All i want it the wires that you really need. i am goin to run them inside the frame so the less the better. Quote
Snopczynski Posted March 7, 2009 Report Posted March 7, 2009 Ok i am taking all the useless wires off my harness, and i ran into this blue one that goes to the voltage regulator(next to the CDI). Do i need that if i am not goin to run lights? All i want it the wires that you really need. i am goin to run them inside the frame so the less the better. You can disconnect the single yellow down at the stator and elimnate the entire yellow and blue wire in the harness if you run no lights at all. Quote
skinindustries Posted March 7, 2009 Author Report Posted March 7, 2009 Ok so that blue wire goin to the regulator thing i can just take that off then right. and if i do that can i get rid of the on/off switch on the bars? i am running a togle switch that works really good. Quote
Snopczynski Posted March 7, 2009 Report Posted March 7, 2009 Ok so that blue wire goin to the regulator thing i can just take that off then right. and if i do that can i get rid of the on/off switch on the bars? i am running a togle switch that works really good. Is the toggle switch for the ignition kill? Quote
skinindustries Posted March 7, 2009 Author Report Posted March 7, 2009 yeah but it doesnt work thats why i put in the toggle Quote
Snopczynski Posted March 7, 2009 Report Posted March 7, 2009 you can eliminate the lighting circuit and the voltage regulator. Quote
skinindustries Posted March 7, 2009 Author Report Posted March 7, 2009 Ok sweet thanks much i am goin to keep thae wires and stuff tho. Just incase something messes up and it doesnt work. Quote
