Ok i am taking all the useless wires off my harness, and i ran into this blue one that goes to the voltage regulator(next to the CDI). Do i need that if i am not goin to run lights? All i want it the wires that you really need. i am goin to run them inside the frame so the less the better.
You can disconnect the single yellow down at the stator and elimnate the entire yellow and blue wire in the harness if you run no lights at all.
Ok so that blue wire goin to the regulator thing i can just take that off then right. and if i do that can i get rid of the on/off switch on the bars? i am running a togle switch that works really good.
Is the toggle switch for the ignition kill?
