Okay, I'm a big single carb fan. However, I'm toying with the idea of going with a pair of 28s as I have 2 thumpers and want to do the best for a stock bore / stroke banshee. I like the 28mm setup a lot for that. I'm also not an airbox fan, it has to go. So with that, should I just keep the carbs on the stock intakes or upgrade intakes?
Also, keeping in mind it's been awhile for me, I'm trying to remember reed setups. I'm going to end up with some VForce for sure but am going to take it super slow first (deal I made with wifey to get it), so should I just upgrade to some Boyesens or what was that other company that makes good reeds for the stock cage.... i could open up the cage a little as well.
I'm probably going to get the PT Hi Rev pipes, if not Fatties, so it'll be that and the carbs for now, and that's it. Then I'll start working on compression.
