I have a stock bore, stock carbs, FMF Fatty Pipes, K&N Air Filter cover removed. I'm using the Vito's carb kit with 290 mains, clip in the third slot How many turns should the air screw be turned out and is the 290 the correct starting point. I'm setting everything for 70-80 degree Wisconsin weather.
Sooner or later it will be 70-80 degrees in Wisconsin...lol
If you have a similar setup, let me know where your at. I would like to be at a good starting point before I fine tune. Thanks
280 to 300 is good, I'd say 290 is a good place to start. Put the needles in the 3rd or 4th clip. Air screw, try 1.5 to 2 turns but you'll have to play with it to fine tune it. What pilot is in there?
Not sure of the size, it came with the Vito's kit
