NickisGod Posted February 23, 2009 Report Posted February 23, 2009 what im looking to solve is, do all banshee exhaust systems share similar geometry? im not asking if every pipe uses the same design, but lets say you own a set of fmf turbine core silencers. would these work on paul turner high rev headers? or are all exhaust manufactures use different exhaust header and silencer placement? Quote
01banch Posted February 23, 2009 Report Posted February 23, 2009 i run pt ids and i do not think they would just bolt on but with a little modification they should be fine, the reason i do not think they will bolt right on is because the pt mids and the fatboys silencers have a piece in betweent them that they both slide over like a intermintent piece? if you understand my babble Quote
NickisGod Posted February 23, 2009 Author Report Posted February 23, 2009 gotcha. so is it worth the hassle do you think? honestly i think fatboy silencers are ugly. Quote
Rodneya Posted February 24, 2009 Report Posted February 24, 2009 Some pipes and silencer mixes may fit together I would not recommend doing it. Each pipe is matched to a tuned length and diameter stinger. If you want the full potential from your pipes, use the silencers recommended by the pipe manufacturer. Quote
01banch Posted February 24, 2009 Report Posted February 24, 2009 I agree the silencers are ugly I plan on getting cascade CSX silencers when i get the cash. Quote
NickisGod Posted February 25, 2009 Author Report Posted February 25, 2009 I agree the silencers are ugly I plan on getting cascade CSX silencers when i get the cash. they fit on pt? Quote
