I've got some bb drag ported cylinders I was running last year. To make a long story short, I've got a 4mil long rod crank now and custom spacer plate from Nate McCoy. I was wondering if you can get longer dowel pins for the cylinders. With gaskets and spacer plate, the dowel pins are pretty much completely swallowed so that's a bit of an issue. Any info would be appreciated. Thanks.
If you are talking about case studs that hold your cylinders down yes you can get longer ones. Nate probably has them otherwise Fast or MMatv would i'm sure as well as Vitos or most other builders.
Edited by RadarRacing
Now that you mention it, I'm probably going to need those too. What I was really after are the dowel pins on the bottom of the cylinders that keep them centered. Any ideas?
