ban06shee Posted February 19, 2009 Report Posted February 19, 2009 i have a 06 banshee with T6 pipes and K&N pods, it was running fine when i got it back from a shop and now when i rev it up and it idles down it makes like a tssssssssssssss or psssssssssssss noise from the right side of the bike and than the other day it did it for the first time on the left side? i have no idea and im shitting bricks just thinking about what it could be? i really need help on this one, i really appreciate it! i run 32:1 gas to oil ratio. and i tried changing the week old spark plugs but its still doing it. :sad: Quote
lokisbuddy Posted February 19, 2009 Report Posted February 19, 2009 There may be a snake trapped in your airbox. :biggrin: take a vid of the problem it may help. Quote
vulvafan537240 Posted February 19, 2009 Report Posted February 19, 2009 air leak or exhaust leak maybe. or like lokisbuddy said, you could have a snake laying on top of the motor and he gets pretty upset when it gets hot. Quote
DallasGDub Posted February 19, 2009 Report Posted February 19, 2009 When you bump the throttle, does it drop pretty quick to idle? Or does it take longer to idle down to normal? If it seems like it is idling high or not droping to a steady idle, it might be sucking air. Maybe around the carbs or intake. If it is normal running and idle, and just making a sound, I would look for exhaust leaks. A leak down test will help you find out if it is sucking air also. Quote
MarineNYC Posted February 19, 2009 Report Posted February 19, 2009 Not to scare u or anything but Wacko's motor was doing the same thing and we were all trying to figure out what it was. about 2 hours later he blew his Left piston. We were thinking that he might of had a air leak on his crank seal. The right piston looked normal and the left had a hole u could drop a dime through. When it was making the noise it was running great. So we thought nothing of it. It seemed to only do it when the engine was spooling down. Quote
DallasGDub Posted February 19, 2009 Report Posted February 19, 2009 Not to scare u or anything but Wacko's motor was doing the same thing and we were all trying to figure out what it was. about 2 hours later he blew his Left piston. We were thinking that he might of had a air leak on his crank seal. The right piston looked normal and the left had a hole u could drop a dime through. When it was making the noise it was running great. So we thought nothing of it. It seemed to only do it when the engine was spooling down. Holly shit'es...I seen the pics, that makes my guts bubble. Quote
TwistedSheeRida Posted February 19, 2009 Report Posted February 19, 2009 don't think it would be your intake boots i had to change mine this year cause they were dryrotted through and it just revved up quite a bit not similar to what yours is doing Quote
ban06shee Posted February 20, 2009 Author Report Posted February 20, 2009 When you bump the throttle, does it drop pretty quick to idle? Or does it take longer to idle down to normal? If it seems like it is idling high or not droping to a steady idle, it might be sucking air. Maybe around the carbs or intake. If it is normal running and idle, and just making a sound, I would look for exhaust leaks. A leak down test will help you find out if it is sucking air also. you know i never bothered to pay attention to that, ima check it out first thing in the morning. now that i think about it, it idles down pretty normal. besides that fact that my throttle gets stuck sometimes and idles a little higher than usual, how would i fix that problem? Quote
ban06shee Posted February 20, 2009 Author Report Posted February 20, 2009 air leak or exhaust leak maybe. or like lokisbuddy said, you could have a snake laying on top of the motor and he gets pretty upset when it gets hot. lol i know for all i know there probably is here in AZ diamond backs everywhere lol i guess ill take it to the shop i got it done at to let them deal with it cause everything was fine till i put the pipes on. thanks everyone! Quote
FireHead Posted February 20, 2009 Report Posted February 20, 2009 There may be a snake trapped in your airbox. :biggrin: take a vid of the problem it may help. Ahhhhhhhh........... you beat me to the joke. :biggrin: Quote
