I'm having starting difficulties which I believe are related to the choke plunger. Anyway, I removed the plunger and during my inspection I managed to dislodge the nut assembly from the rod and am unable to get it back together.
Is there a clip that holds the nut onto the plunger rod?
Anyone got a pic or diagram of all the parts and their orientation?
Thanks!
-PC
Thanks!
-PC
did you pull the knob off the end? anyways, there is a little wire clip under the boot that locks it in the knotches, and wears out often, then you have to buy a new plunger. spring, nut, then knob. 4 things to check on the choke circut; the tube between carbs, the o-ring on the end of the plunger, the bowl on the left carb should have a brass bead you can see from the outside, facing the cylinder, and the slides have holes that shouldn't be covered by the cable retainers. there is also a little choke jet inside the bowl, where that little bead is on the outside :thumbsup:
I didn't take the knob off, butI did manage to dislodge the clip :banghead:
Hopefully it's still floating around in there and is reusable.
Thanks for the info!!! Much appreciated.
