MikeNick Posted February 14, 2009 Report Posted February 14, 2009 Is this tab here needed, the one with my finger pointing towards it. What is it for,??? I looked on my Banshee and theres nothing attached to that bolt hole on it either..Was thinkin bout cuttin that piece off b4 PC.. This would be on the clutch side of the frame also right behind where the rear master cylinder is.. I already cut off the front fender mounting brackets and original pipe hanger brackets... Quote
C&B Posted February 14, 2009 Report Posted February 14, 2009 Its the foot gaurd mount. If youre just runnin the pegs, no Quote
hercalmighty Posted February 14, 2009 Report Posted February 14, 2009 Thats for the heel guards. Quote
MikeNick Posted February 14, 2009 Author Report Posted February 14, 2009 Thanks fellas...It's gettin cut off... :cool: Quote
ohiobanshee Posted February 15, 2009 Report Posted February 15, 2009 Go ahead and grind off the tors mount under the tank,weld the motor mount holes closed on the outsides of the frame.Make that thing purdy. Your garage looks like mine. :laugh: Quote
MikeNick Posted February 15, 2009 Author Report Posted February 15, 2009 Go ahead and grind off the tors mount under the tank,weld the motor mount holes closed on the outsides of the frame.Make that thing purdy. Your garage looks like mine. :laugh: Could ya give me a pic of the TORS mounts...Never seen one with them so I have no idea what they look like..Dont wanna cut off shit I need!!!!!!!!!!!!!!!!! haha :biggrin: Quote
ohiobanshee Posted February 15, 2009 Report Posted February 15, 2009 It's the little tab beside your coil mount on the left side. Quote
MikeNick Posted February 15, 2009 Author Report Posted February 15, 2009 It's the little tab beside your coil mount on the left side. Ok thanks man Quote
peterlocal22 Posted February 15, 2009 Report Posted February 15, 2009 you going to paint your frame after you cut the tabs? Quote
MikeNick Posted February 16, 2009 Author Report Posted February 16, 2009 you going to paint your frame after you cut the tabs? I am having OHIOBANSHEE powdercoat it... Quote
