nfk Posted February 8, 2009 Report Posted February 8, 2009 I just got another banshee from a guy that had it tore apart. I am in the process of rebuilding it and getting it running again. It has stock carbs, K&N pods, T5's, boysen reeds, and a port which he thought was a dune/play port. My elevation is 2000'. I tore the carbs apart and saw that he was running 260 mains. This seems lean to me, he said it ran good when it ws together. I will be doing a plug chop when it is together but I just wanted another opinion on the Mains or if I should try starting out a little richer. Quote
jasons Posted February 9, 2009 Report Posted February 9, 2009 I just got another banshee from a guy that had it tore apart. I am in the process of rebuilding it and getting it running again. It has stock carbs, K&N pods, T5's, boysen reeds, and a port which he thought was a dune/play port. My elevation is 2000'. I tore the carbs apart and saw that he was running 260 mains. This seems lean to me, he said it ran good when it ws together. I will be doing a plug chop when it is together but I just wanted another opinion on the Mains or if I should try starting out a little richer. i am pretty much running that same set up. but i am just running on a clean port what ever that means.and i am at sea level so mine maybe different. and my mains are 340. seems to be doing the trick for me. Quote
nfk Posted February 9, 2009 Author Report Posted February 9, 2009 i am pretty much running that same set up. but i am just running on a clean port what ever that means.and i am at sea level so mine maybe different. and my mains are 340. seems to be doing the trick for me. I thought 260 sounded lean...I will have to get some bigger jets and start messing with it when I get it back together Quote
