well 22 divided by 20 is 1.1
14 x 1.1 is 15.4
41 divided by 1.1 is 37.27
so you either need to go to a 15-16 tooth front sprocket or a 37-38 tooth rear to get close if your only planning to buy one gear. you can always do a 15-40 combo and get even closer.
without actualy measuring the roll out of your tires and crunching more numbers to fine tune it thats a good start.
i'm assuming your riding on somewhat flat ground since your willing to lose the height of the tire?
14 x 1.1 is 15.4
x2
