natedogg Posted February 3, 2009 Report Share Posted February 3, 2009 i have a problem there is a lot of white smoke coming out of one of my exhaust pipe Quote Link to comment Share on other sites More sharing options...
Fireroad Express Posted February 3, 2009 Report Share Posted February 3, 2009 coolant leak! Quote Link to comment Share on other sites More sharing options...
natedogg Posted February 3, 2009 Author Report Share Posted February 3, 2009 they were new gaskets had new pistions and cylinders done Quote Link to comment Share on other sites More sharing options...
natedogg Posted February 3, 2009 Author Report Share Posted February 3, 2009 somebody said i was burning oil Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 3, 2009 Report Share Posted February 3, 2009 what side?? Quote Link to comment Share on other sites More sharing options...
Rodneya Posted February 3, 2009 Report Share Posted February 3, 2009 Its a 2 stroke, you are always burning oil. If you are leaking gear oil it will burn really thick white and you wont be able to see anything behind you. Burning coolant will make a bit of white smoke and smell kind of sweet. Quote Link to comment Share on other sites More sharing options...
natedogg Posted February 4, 2009 Author Report Share Posted February 4, 2009 what side?? gear shifter side and its not the coolent Quote Link to comment Share on other sites More sharing options...
natedogg Posted February 4, 2009 Author Report Share Posted February 4, 2009 there is no coolent smeel Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 4, 2009 Report Share Posted February 4, 2009 could be blow-by..and you just noticed now.if it was water it would look more like steam..and at times you could see the water coming out of the silencer.... Quote Link to comment Share on other sites More sharing options...
natedogg Posted February 4, 2009 Author Report Share Posted February 4, 2009 could be blow-by..and you just noticed now.if it was water it would look more like steam..and at times you could see the water coming out of the silencer.... it smeel like gas coming out the silencer it was a lil wet too Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 4, 2009 Report Share Posted February 4, 2009 might be water..does the smoke look like steam???did you torque your head down?? Quote Link to comment Share on other sites More sharing options...
natedogg Posted February 4, 2009 Author Report Share Posted February 4, 2009 might be water..does the smoke look like steam???did you torque your head down?? yea torque them down and i did a compression test today and they both had a 115psi Quote Link to comment Share on other sites More sharing options...
tony cub Posted February 4, 2009 Report Share Posted February 4, 2009 what do you have done to your motor??what head??have you check your water reserve tank for bubbles??if the head gasket is out you will see bubbles in the tank when you rev it. Quote Link to comment Share on other sites More sharing options...
natedogg Posted February 4, 2009 Author Report Share Posted February 4, 2009 what do you have done to your motor??what head??have you check your water reserve tank for bubbles??if the head gasket is out you will see bubbles in the tank when you rev it. 60 over pistons vforce3 boost bottle thats it i think the carbs are f up Quote Link to comment Share on other sites More sharing options...
AKheathen Posted February 4, 2009 Report Share Posted February 4, 2009 could be blow-by..and you just noticed now.if it was water it would look more like steam..and at times you could see the water coming out of the silencer.... blow by? it's a 2 stroke. any blowby gets pumped back into the chamber in the next stroke. what do the plugs look like? Quote Link to comment Share on other sites More sharing options...
