never use a screwdriver to "pry" the cases apart, this is a machined surface and this "prying" will destroy the surface. Also you do not have to take the center bolt/clutch adjustment mechanism out of the center of the pressure plate.
sorry, its been awhile since ive done that, i forgot about the clutch thing.
as far as prying, i never had any horror stories, but i was real careful.
okay guys just got the clutch off and the gears with the shields
do i need to take the ones off the crankshaft??
also would i need to undo the bolts holding the case backwards??
if someone could call me and walk me through it i would be very thankful
908 295 8244 Dave
:thanks:
the drive gears on the crank do not have to come off. take off all bolts on top and bottom of the case in order according to your manual. make sure you keep them in order with their numbers.
okayy guys i got it all apart and i ordered new seals for the crank and shifter..
and thing else i should look at while i have it apart??
also wen i seal her up were di i put the sealent?? the whole perimiter including the seals? sorry for the stupid questions haha gotta learn
Edited by klemet banshee
if you havent already your gonna have to take the gears off of the crank. Otherwise you won't be able to replace the seal. And yes put sealant all the way around the perimeter of the cases and any other area you can see that is machined. It would be easiest for you to just look where it was sealed before. Put sealant all the way around the crank seals and sprocket seal as well. Be sure not to forget the bearing clip/retainers like we talked about on the phone. Have all the nipples on the bearings in the cutouts as well.
it does have to come off to replace the seal, but not to split the cases. thats what i was saying
to take off the gears off the crank wat side thread is it? left right or wat? cause on my frineds there was a clip that stoped it and he ened ripping the threads off haa
its just a normal thread, lefty loosey, righty tighty :biggrin:
