zachass9 Posted January 28, 2009 Report Posted January 28, 2009 DOES ANYONE KNOW IF THE STOCK STATOR WITH A DC CONVERSION ( FLOAT GROUND and ADD A RECT/REG) WILL RUN THE SCMR16 HID LIGHTS FROM TRAIL TECH? TRAIL TECH SAID THEY THINK THE STOCKER WILL, BUT THEY ARENT SURE!! PLEASE HELP ME OUT TRYING TO DECIDED ON MAKING A PURCHASE!! Quote
AKheathen Posted January 28, 2009 Report Posted January 28, 2009 DOES ANYONE KNOW IF THE STOCK STATOR WITH A DC CONVERSION ( FLOAT GROUND and ADD A RECT/REG) WILL RUN THE SCMR16 HID LIGHTS FROM TRAIL TECH? TRAIL TECH SAID THEY THINK THE STOCKER WILL, BUT THEY ARENT SURE!! PLEASE HELP ME OUT TRYING TO DECIDED ON MAKING A PURCHASE!! i belive they are only 30 watts. in which case, yes, but you should add a battery or they will flicker/change color. stock stator is 70 watts, i belive Quote
grizzly700 Posted January 28, 2009 Report Posted January 28, 2009 DOES ANYONE KNOW IF THE STOCK STATOR WITH A DC CONVERSION ( FLOAT GROUND and ADD A RECT/REG) WILL RUN THE SCMR16 HID LIGHTS FROM TRAIL TECH? TRAIL TECH SAID THEY THINK THE STOCKER WILL, BUT THEY ARENT SURE!! PLEASE HELP ME OUT TRYING TO DECIDED ON MAKING A PURCHASE!! If it's not enough power u can prolly have it rewound at a local auto electrician for pretty cheap and watever wattage u want. Quote
zachass9 Posted January 28, 2009 Author Report Posted January 28, 2009 I forgot to add that I was also adding a battery!! Thanks for the input!! Quote
Snopczynski Posted January 29, 2009 Report Posted January 29, 2009 A stock stator with a dc conversion wont run those unless you add a battery as well. Stock stator is 100 watts. The MR16 trail techs in a set would draw 14 amps on startup, and pull 5.8 amps at running temperature. Quote
zachass9 Posted January 29, 2009 Author Report Posted January 29, 2009 Sorry!! I am definately adding a battery, just forgot to post!! thank you for the input!! Quote
