Guest utleybanshee Posted January 16, 2009 Report Posted January 16, 2009 what do i need to replace on my banshee to get the left front wheel to stand up straight like the right front wheel.. Thanks in Advance... Quote
blowit Posted January 16, 2009 Report Posted January 16, 2009 A new bike should get you fixed up.... can you just bend the wheel back over with a prod bar? Quote
bonbon Posted January 16, 2009 Report Posted January 16, 2009 What did you do or did you get it that way? And your shocks are upside down. Quote
RIPPEN Posted January 16, 2009 Report Posted January 16, 2009 Doesn't really look like it in the pic but is the area on the a-arm(upper) where the ball joints are bent? I have seen that many of times.. RIPPEN Quote
98_shee Posted January 16, 2009 Report Posted January 16, 2009 It does look like the shocks are on upside down. You may have a bent a-arm or spindal. Quote
sinisterboo Posted January 16, 2009 Report Posted January 16, 2009 thats is 100 percent bent spindle. Look where the top of the ball joing is in relation to the wheel from side to side..... Quote
sinisterboo Posted January 16, 2009 Report Posted January 16, 2009 you have a right side spindle, he needs a letf, LOL unless yours is bent to match his. Quote
sinisterboo Posted January 16, 2009 Report Posted January 16, 2009 when your are sitting on his bike, it would still be the left..... Quote
Guest utleybanshee Posted January 16, 2009 Report Posted January 16, 2009 when your are sitting on his bike, it would still be the left..... thanks i have a spindle im gonna try changing it tomorrow.. i already had changed the top a arm.. Quote
98_shee Posted January 16, 2009 Report Posted January 16, 2009 thanks i have a spindle im gonna try changing it tomorrow.. Sorry it looked like the other side was messed up. my bad. Quote
Guest utleybanshee Posted January 16, 2009 Report Posted January 16, 2009 Flip those shocks over, geez! bike was like this when i got it trying to fix it back up thanks... :cool: Quote
AKheathen Posted January 16, 2009 Report Posted January 16, 2009 it also looks like the upper bushing@ the frame is messed up too, from the first pic. and if those are sno-go shocks, they are supposed to be that way. Quote
bansheejoel Posted January 16, 2009 Report Posted January 16, 2009 it also looks like the upper bushing@ the frame is messed up too, from the first pic. and if those are sno-go shocks, they are supposed to be that way. what is a sno-go shock? BTW those are stockers Quote
AKheathen Posted January 16, 2009 Report Posted January 16, 2009 what is a sno-go shock? BTW those are stockers snow machine shock. the ones on my skidoo summit look the same, but they are meant to run with the body on top, so they don't freeze up like my shee did Quote
