hey if someone could school me on what a powervalve achieves and how it works???
This technology has been beat to death in other threads. Please do a search and you will find all you need to know about power valves. In short, you ride woods and tight, technical stuff, you want it. You drag only, you do not need it.
Brandon
the powervalve basically adjusts your exhaust duration depending on rpm. at lower the rpms, the powervalve is closed which results in more low end power. As rpms increase the valve opens increasing your top end.
