I have a stator with stock timing plate, voltage regulator, and a coil. Are you wanting a flywheel puller? I've never shiped to canada so i have no idea how much it will be.
yes ido need a flywheel puller,if you could tell what size the box would be and how much you think it weight woud be plus your zip code ,i can find out on this end.how much did you want for your parts
thanks jeff
