freddy Posted January 5, 2009 Report Posted January 5, 2009 can i replace the connecting rods on my stock crankshaft with +5 connecting rods and make it a stroker crankshaft?? thanks guys Quote
278 Posted January 5, 2009 Report Posted January 5, 2009 can i replace the connecting rods on my stock crankshaft with +5 connecting rods and make it a stroker crankshaft?? thanks guys No, its not the rod that makes it a stroker you can put a long rod on there and it will reduce some of the stress against the cylinder walls. But the crank journals are what make it a stroker they are 2mm longer so the rod goes up 2mm and down 2mm farther than stock 2+2=4mm. Hope that helps man Quote
freddy Posted January 5, 2009 Author Report Posted January 5, 2009 No, its not the rod that makes it a stroker you can put a long rod on there and it will reduce some of the stress against the cylinder walls. But the crank journals are what make it a stroker they are 2mm longer so the rod goes up 2mm and down 2mm farther than stock 2+2=4mm. Hope that helps man makes perfect sense. thanks man Quote
