jasons Posted December 25, 2008 Report Posted December 25, 2008 i was given a banshee last night that doesn't run. he said all it heeded was a coil or cdi box. well i replaced the coil today because that was the cheapest prt cdiifyone has them instock which i doubt. anyway he knew nothing about the bike as it was his brothers that pass away. all i know is that it has cool heads on it t5 pips its been jetted and has a few billet peices on it. do you think the engine has been bored out and what do i need to find out. i am also assuming the carbs are stock not sure how to find out. i just want to get this thing running first. Quote
bansheerage Posted December 25, 2008 Report Posted December 25, 2008 check the for sale section here. you can find everything there. alot of guys on here part them out all the time. usually pretty cheap too. good luck Quote
Wildcardracing Posted December 25, 2008 Report Posted December 25, 2008 You would have to measure the bore to find out if it has been bored. Stock bore is 64mm, the next common size up would be 64.5mm and then every .25mm after. 66mm is the service limit of most banshee cylinders which is .080" over. Quote
